burying pipes in copper floor
4 Oct 2011
Wolverhampton
Hi all, I just want to make sure I'm doing this correct. I've got a hot and cold pipes that are going in a solid uninsulated floor in the kitchen. I've dug down to the dpm layer, about 3 1/2"
I was going to wrap the pipes with corrosion resistance tape and then add insulation around them.
Then pack around it with building sand and then screed over.
Does that sound correct. Thanks
Insulation only is ok if you're putting sand around it. Copper doesn't corrode in normal concrete or mortar anyway.
Not strictly true.
Copper will corrode very well if there are any traces of dampness!
Tony
We've had copper pipe supplying water to our house for the last 56 years. It was fine when dug up in 2013. Unless you're anticipating chemical attack or running water I wouldn't worry.
http://tinyurl.com/qc37jnx
Copper (Cu)
Copper embedded in concrete and/or mortar is usually roof flashing. Embedded copper is practically immune to reaction with corrosive alkalis, even if exposed to constant moisture. Copper will not react with dry, hardened concrete and/or mortar. Rainwater leaching, however, may bring chlorides in contact with the metal. Corrosion may occur and result in a green discoloration or runoff. Consequently, chloride admixtures should not be used in concrete if contact with copper is expected.
Ask any 'time-served' plumber (we know how old we are and how many years in the trade we have under our belts), and ask if they have any unprotected copper tube under the concrete screeds in their gaffs.
Sheez, its not just the cooks sieve effect we constantly find, the expansion/contraction that causes the pipe to become work-hardened and brittle is also very conducive to failure...
as a minimum, duct tape as a first layer and either the tubular or hair-felt tube type to allow room for movement.
DH
Copper (Cu)
I once removed a gas pipe that passed through a damp brick wall unsleaved. When it was removed it was like a teabag so your post I'm afraid is garbage.
Underground copper is much thicker than standard copper pipe though.
