Hello,
I have been putting together the new consumer unit for my house to make sure it's all OK before I fit it in. With the new regulations, I am going to be installing a Dual RCD CU. This consumer unit has two separate neutral wiring blocks, the same as a normal split way CU. This is where I have got a bit stuck. Do the two RCDs require their own neutral wiring block apart from each other (as i have wired in the pic attached), or can they both be on the same one... OR shall I stick the connecting U copper bar back in between them? There are going to be no RCD unprotected devices in here.
The reason I am stuck is that I don't know if one RCD will interfere with the other on the Neutral if one was to trip. Is it OK for them both to share a common Neutral?
Note the wiring isn't finished in the picture yet - I have connected the live from the isolator to the inputs of each RDC and the Neutral outputs of each RCD to an individual Neutral wiring block.
Thaks in advance for your help and advice!
Cheers,
Tony
