Microbore radiator change
16 Jun 2007
Glasgow
Hello,
I am looking to replace the radiator in my bathroom with a towel rail, but I have a microbore pipe system. The radiator just now doesn't work well anyway as it's a new style radiator but with a one end microbore valve so the cold flushes the hot water basically straight away as you'll see in my photo.
The other issue i have is that i have a slate floor which so i don't really wanna have to try and lift the tile that is at the radiator if i can help it.
Could i take off the valve or just cut the pipe and then run a new pipe along to the left hand side of the rad and then put on a new valve on the right side where the pipes come up through the floor?
Or would you recommend cutting the pipe under the floor and lifting the one tile and putting in new 15mm pipe?
Any advice would be great, thanks
twin entry valve
you could just drain and cut the pipes as you say and fit two valves
that baby won't work with a towel rail
fwiw it probably don't work to well cos the spreader pipe is missing from the inside of the rad ;) View media item 17099
twin entry valve
Yea you're right there is no pipe so the water mixes straight away.
if i don't put in a towel rail i at least want this radiator to work properly, would you just run some microbore pipe along to the left and put a new valve and then just get a new valve for right hand side or would you cut and put in 15mm pipes??
just get a lengh of 8mm and screw it into the valve as in pic
if you want to get rid of the valve just extend the pipe to the other end
above or below floor is your choice
if your going for a towel rail 8 will be ok
well as long as its not a 2 m rail :LOL: :LOL: ;)
btw if you keep the valve the screw under the brass cap is a valve to close the return off
no need to drain system
I can't just put in a pipe as the radiator is a new style one so the pipe cannot go along the bottom of the radiator like on my other radiators
So if i cut the cold pipe and feed a new pipe over to the left hand side and put on a new valve in that side and close off the cold on the existing valve that'll work??
For putting in the new valves do i need to drain my system, when i cut the cold pipe surely water will pish everywhere?
personally i would renew the lot ie both
if your gonna drain the system you might as well do the job right
then you can have your towel rail and keep err indoors appy as well ;)
Ok so if i do renew the pipes to 15mm under the floor, do i just cut the pipe under the floor or do i have to remove all the 8mm pipe back to where the main pipes are 22mm??
if your gonna renew pipework you might as well take it back to the 22
for a towel rail i wouldn't bother
but hey its your gaff
your choice fella ;)
ok sweet, i'll just cut the pipes under the floor and then feed up new pipes to either side and put on valves.
One last question, what do i use to connect the 8mm to new 15mm pipes so i don't have to solder?? Or do i have to solder?
Cheers
