Does anyone know if you can get a telephone socket with a filter and broadband socket combined. I'm sure that there are loads of people getting peeved off with filters hanging off a 4" cable
Pensdown said:Do you only need one or do you have to fit them to all used outlets as you do with the external filters?
use a double plate that has independent phone and RJ11 sockets on itbreezer said:how are yougoing to connect the pc to the dsl? it will need a socket to plug into, but you cant do that since you have a bt soket there for the phone.
its certainly a quick way of making an existing install neater, but seperation in a signal place should cause less reflections etc which should result in better reliability/performance especailly with the new higher speed versions of DSL and on longer exchange lines (where things are getting marginal already).yes you can buy a "dsl" socket, but that means you have 2 sockets side by side, which is a waste so why not buy a double socket, one with phone, one with dsl, which is where this topic started.
i assume the reason people start asking about other soloutions is because they wan't to avoid using those ugly things.better still just use the plug in adsl filter
or if you wan't a neat install use claritys version with an extra pair of terminals on it.bernardgreen said:Use a plugged lead into the ADSL socket to run to the computer area.
i thought they all did, connecting a ringer to the cap in the master box could seriously compromise the ADSL signal.I was surprised to find some micro-filters have 2 wire connection to the phone socket and have a bell capacitor fitted to feed the bell in the telephone and thus do no use the capacitor in the master box. This can compromise the qualitity of the speech and affect ringing efficiency.
