Wireless PIR's on a wired system
16 Sep 2004
Leeds
Hi guys
Is it possible to retro-fit a wireless PIR to a pre-existing wired alarm? Currently have a Texecom Veritas R8 alarm system and wanting to add protection to my detached garage (about 10 metres from the house). I was going to install a separate wireless alarm with one PIR, but then got thinking is it possible to have a hybrid wireless / wired system?
Yes you can but you will need a compatible standalone receiver
a Scantronic 762 is a standalone receiver that will accept scantronic wireless sensors, you can then wire the receiver into a spare zone on the R8. Alternatively there is the risco nova 4 that is a stand alone receiver for risco peripherals.
But your room may not be suitable for a pir and currently there are only wireless pirs available not dualtecs etc.
If you need a dualtec then you will need a local psu and a universal transmitter.
Thanks. It's for a garage about 10m away from the house. Would it be best installing a separate alarm just for the garage?
Not really.
it depends on your current alarm system and how clever it is but depending on routing to the garage (eg/ soil/concrete etc) you could always fit a cabled PIR or 2 from the main unit and program it/them as a seperate zone that is armed even when the house is not (eg at night)..
Does the garage have mains etc? If so it might be easier to fit a seperate system but to enable control from the house you will still need to wire to the garage.
In my experience cheap wireless alarms are not worth touching. The only ones I use are Eurotec CPX systems and they are exteremly good and no false alarms from passing police cars and whatnot.
But if it were me I would want it extended on to the current system..because wireless reliabilty in the house is a different ballgame to a wireless link through double skinned brick wall and then through the big wide world and into another brick building!
The bigger texecoms ie the premier will accept a wireless expander, but the veritas will not. The only way is to use a standalone reciever. If you use the risco reciever its the same rf gear as the Eurosec CPX.
Personally id plumb for the scantronic rf. But thats just my own personal view, risco is great when using their panels, ie 490x cpx 595 etc, domonial rf gear is probably the best IMO on a honeywell galaxy, but if you want to interface with what you have you will need a standalone reciever.
