I Have a big earth wire going into the service head with the neutral and a couple of loose strands stuffed in the side which connect to the old CU.
However i have a new CU located somewhere else with a 16mm Earth supplying it. There is no way that a 16mm earth will be squashed into the service head with the main earth.
I am wondering what to do? Is it best to connect the main earth to a nickel plated block then run a single 16mm earth into the service head(with the neutral), and then connect my other 16mm earths to this block?
or should i get the electric company out to provide me with a proper MET that i can connect into.
I am also not sure is via the neutral and the big earth wire is supplementary, or is infact the only earth
Cheers
Adrian
Cheers
Adrian
