Banging Apollo
9 Nov 2010
Yorkshire
i have a myson appolo 50
when ever the hot water or the central heating turns on i get a loud banging noise
can anyone help me?
the boiler fires up.
after about 10 mins makes a banging noise.its continues like every couple of minutes. same for hot water and central heating.
i have a tank fed system
You have a hi and lo stat on boiler does it make noise if either is selected.
water is in the header tank but had this systems for years so i think the ball valve mite be out on its last leg.(wear and tear)
check the pump it seems ok..
did the screw driver trick cab hear the popelar humming.
