- Joined
- 6 Mar 2024
- Messages
- 8
- Reaction score
- 1
- Country
Good evening all,
I have an exterior pond which has an armoured cable running from inside the garage which is connected to a separate consumer unit just for the pond electrics. I recently attempted to carry out some electrical work to connect the pond pump and UV steriliser units to the armoured cable which runs into an enclosure behind the pond. I don’t believe that I am colour blind but the armoured cable has four black cables and an earth. It also looks like a further two black cables have been taped down so are not in use. There is also a braded cable which has been taped down so is not in use.
I would much appreciate learning how it is possible to connect a three core cable from say the pond pump to the correct black wires. The earth cable is the only one that does not need guessing.
Thank you so much.
Thank you so much.
