We are new to this so hope someone may be able to help. We are currently converting a 3 storey Victorian semi into a B &B. It used to be a B &B until 1996 and has been a private residence since then. No promblems with planning but building regs have put a real spanner in the works. They are insisting that we either install lobbies to every room on the grounf and first fllor or install a sprinkler system. lobbies are not an option as they would not fit in some rooms and would compromise the buildings arcitecture. A sprinkler system is very expensive and may not be possible with our current mains water supply. We were planning to fit a full L2 fire detection system, emergency lighting, and fire doors but building regs say this is not enough. He quotes clause 4.34a at us all the time as needing lobbies because we are more than 1 floor above ground level. To compound the issue when we were buying the property all he said we needed was mains smoke alarms and fire doors but he denies this now. Anyone got any ides on how we can persuade him we can conform to Part B regs? Thanks
