Wholesale and retail wireless security alarm syste
V
  • vedardalarms
Features: <br><br>1) 16-zone (8 wireless and 8 wired) with 4 x 4 keyboard and lattice LCD display <br>2) Voice pre-recorded <br>3) 8 partitions can be programmed independently; 8 remote controllers and 8 <br>user codes can be programmed for 8 partition to ARM/DISARM independently <br>4) Supports ADEMCO CONTACT ID and KS6+2 monitoring center communication <br>protocol<br>5) Access codes, 1 installer code, 1 master code, 8 common user code and duress <br>code <br>6) Dial 5 telephone numbers (mobile and pager number); dialing type (tone or <br>pulse) and appointed communication zone can be programmed; alarm <br>telephone is priority <br>7) Option for ARM/DISARM and system status report or not <br>8) Phone line cut or short-circuit will send an alarm (indicator or siren for optional)<br>9) Remote arm, disarm, monitor, and on-site alarm setup <br>10) Automatically register between wireless PIR detector, remote controller and <br>main console (8 wireless can up to 24 zones, and 8 remote controllers)<br>11) Wired zone respond speed: 5ms - 1,000ms; supports normal open, normal<br>close and end- of-line resistance at freedom <br>12) Zone attribute can be program for fire alarm, medical alarm, emergency alarm<br>at freedom; each zone can be programmed with different remote control <br>13) Two timers can be set to arm/disarm independently <br>14) Alarm delay (00 - 99 seconds) and arm delay (00 - 99 seconds) can be set for<br>appointed zones <br>15) Main unit disassembly, slave detector disassembly, AC power cut, backup <br>battery lower and slave detector power lower will activate alarm <br>16) Work with wired/wireless siren and linkage device <br>17) Latest 30 pieces alarm (month/day/hour/minute) can be recorded and can not<br>be deleted; last arm/disarm time can be remembered <br>18) Main unit and wireless PIR detector make communication times in 26 hour to<br>check if there is communication malfunction; if there is a malfunction, the main<br>console will alert corresponding zone within 26 hours <br>19) Slave detector sends report to main unit for on/off; the report will be<br>remembered in record <br>20) Both AC 220V and 12V, 7Ah rechargeable battery power supplied; and <br>change automatically; the backup battery can work 24 hours or more in standby<br>21) Battery lower power alert and discharge protection<br>22) Telephone lightningproof
Home Security
vedardalarms
67.6 KB
750px x 774px
