What's needed?
Unless the make of the broken TRV head is known then it's a hit 'n' miss whether another head will work, unfortunately they are not all made equal.
Hi all, ok, couple of pics here. For the record, the ones on the other rads are unbranded, cheap looking things.
This is the broken one ..
And it needs to go here ..
Not one I’ve heard of. You could chance it with a trv head, but probably best replacing with a whole new one.
I was hoping to just replace the head. Putting a whole new valve on may mean draining my the system etc, bit beyond me all that.
Most electronic heads come with a kit
so they can fit a range of TRV bases. The eQ-3 and Terrier i30 are stand alone, ⁣⁣ but61dmtMm13BL.jpg1742439835449.png many need a hub as well, home Wi-Fi needs a lot of power, so most battery powered items, need a hub to make the batteries last longer, in the main over a year for TRV heads, I did a quick look for cheap electronic heads, and the SONOFF does seem cheap, and has a great Compatibility Guide which shows all variations.
