Of what type - fixed voltage or fixed current? And what voltage or current?Just fitted an LED transformer
No tranny with LV lights. Low voltage AC = 50–1000 volts, @ferkh10 is using ELV lamps or extra low voltage, so below 50 volts AC or 75 volts DC, this is UK not USA, only USA calls 12 volt low voltage, everywhere else it is extra low voltage.
Maybe because you have fed the new one with only 12 volt from the existing power supply.Now I’m more confused. Just fitted an LED transformer to that last bulb and now it doesn’t work at all. Do all of the bulbs in the circuit need to have a transformer fitted?
I think that looks like an ATX PC style PSU, Of course it doesn't exclude it being repurposed for the lights.Maybe because you have fed the new one with only 12 volt from the existing power supply.
as asked earlier whats the white box with slots in, it looks like a power supply unit feeding the jb and white rectangular box that distributes out to all of the 12v lights
If that's the case, how did someone else manage to post a message which appeared to be from you, which said:Did I mention LV - no
LV lights have 3 points of failure…
Whatever those two Junction Boxes in the 1st photo are doing, they should both be fixed to a Ceiling Joist, or some other solid timberI have these 2 boxes (one black, one white) in the loft where the lighting cable goes into, then out of and services a set of 16 halogen downlights across 2 bathrooms.
Then this is what the connection to each downlight looks like.
Where do I put the transformer? Is it replacing the 2 boxes or do I need one transformer per bulb and put the transformer just above the bulb cable?
There is more to this than meets the eyes.Sorry, been busy for a few days. Here’s what’s inside that white box.
It is an old PC PSU, it’s in the loft just stored with other PC bits - nothing to do with the lighting
Could well be an old wired house alarm (decommissioned) in the mix also.
As above, will rewire with GU10 fittings. Assume that will fix the flickering problem?
Finally, what’s the connecting block to use? Wagobox?
Post 1 picture looks like a G5.3 push in 12 volt lampholder and MR16 12 volt lampThere is more to this than meets the eyes.
Let's go back to the beginning, what lamps have you purchased: 12V or mains 230V?
Any chance of tracing the cables.
Yes I think that is correct but I have encountered them in mains voltage too... Yeah, total PITA when I replaced with 12V without realising the error. And so far we are not privy to any form of transformer but there is a 12V dc relay.Post 1 picture looks like a G5.3 push in 12 volt lampholder and MR16 12 volt lamp
and yetwill rewire with GU10 fittings.
G10 lamps were originallyHere’s the LEDs I bought.
Integral LED 12V MR16 GU5.3 Lamp
Save energy by choosing these Integral LED lamps for all your indoor lighting requirements. The bulbs feature a stylishly engineered lens that produces a spotlight for directional lighting, allowing you to illuminate particular areas or highlight specific objects. This makes them a popular...www.toolstation.com
Cables under boards - in the ceiling space ?!?!Cables are under boards will loads of stuff to be moved to get them up, bit of a pita to trace
Yes - but only if you remove whatever transformers/drivers/converters/power supplies are there for the old lights, and preferably remove all of the junk and obsolete wiring.Would replacing all of the units solve the flickering problem though?
