I was told it was accepted and desirable for rebar to be rusty, by a civil engineering lecturer way back in the 20th century! The pitting helps the concrete grip, and it all gets completely neutralised/preserved by the cement anyway. It seems logical, there's some evidence supporting it online but I really don't know enough to get into a keyboard war about it.
It can be placed in the middle or top or bottom, depending on the needs. For a beam it's normally near the bottom as that's where the tension is. For a slab it's often in two layers, one is near the bottom and the other near the top, as you don't know in advance where the compression and tension will be. In the middle arguably helps a little either way. Whatever though, it needs to be covered, i.e. at least a reasonable depth below any exposed surface. As yours will be inside a building it doesn't matter at all. Just as long as it's not sticking out so you'll trip over it on the way to the fridge you have nothing to worry about!
But what you have is way beyond what many builders use so don't worry.
Cats are a hazard! I had a few marks from our little angels in the past. They learn though, after I'd done a load of concreting while sorting the garden I saw ours walk up to the edge of a new bit and gently press it with one paw. Then only after checking it was solid she walked on it. Bless.
