Hi folks,
I have a Vaillant Combi Boiler, either a VCW-GB 242 EH or a VCW-GB 282 EH, can't seem to be able to confirm this. The hot water from the taps is working fine, problem is with the central heating.
The central heating did not come on this morning and the pressure gauge was registered at about 2 bar, which is what I thought the problem was. I dug the manual out and found the pressure release knob, and release some of the pressure so it was just above 1 bar. For some reason, it has now gone down to 0 bar, and when looking at the manual it recommends getting the system topped up.
1. Do you think the central heating did not come on because the pressure was too high?
2. How do I go about topping up the system to approx 1 bar, the manual says to get a plumber in to do it?
3. Is there a few other things I can check that may have caused the central heating to have failed?
Thanks very much.
Dan.
Thanks very much.
Dan.
