keeping this as short as possible. ground floor flat, stone built, 75+ years old. damp on lounge wall at chest height. damp specialist has narrowed down water ingress to faulty downpipe and pointing. recommends as follows:
EXTERNAL OBSERVATIONS
REAR ELEVATION
Faulty and unsatisfactory downpipe, cracked and boss stone work and pointing also very porous, this being long standing.
RECOMMENDATIONS
Remove downpipe, repoint behind downpipe with a damp proof membrane substrate and replace faulty downpipe. Rake out faulty joints within stonework and cracked stonework, repoint using sand and lime and a recommended water proofer mixed through. Apply 2 coats of enviroseal to porous sandstone to act as a major water proofer as this being one of the main problems of the water penetrating through sandstone.
INTERNAL OBSERVATIONS
PENETRATING DAMPNESS
Lounge back wall adjacent to kitchen and doorway lintel wall
At the time of our inspection there were very excessive visible signs of penetrating dampness supported by moisture readings recorded with an electronic moisture meter revealed evidence of penetrating dampness was located in areas mentioned. Faulty downpipe and stonework i.e. pointing and porous attributing to the main cause of dampness.
RECOMMENDATIONS
Strip contaminated plaster from ceiling to floor levels, Apply a damp proof membrane (D.P.M) to walls, re-plaster, skim coat and finish.
Estimated costs of works - £2,495.00
my train of thought (partly to reduce costs, partly cause I'm always concerned I'm being quoted for works that aren't required) is to ask for all external works only to be completed and then see if internal damp dries out given the cause will have been rectified. I should point out however the damp has been present for a number of months so will no doubt be x times worse inside wall. company advised no guarantees can be given unless all works completed and that there could be wet/dry/fungal rot that will still need treated but won't be visible unless they remove internal plaster etc.
I've been reading up on unnecessary damp treatments being offered and would like peoples thoughts on whether I should simply fix the cause (exterior) or go belt & braces and get interior repaired as well?
REAR ELEVATION
RECOMMENDATIONS
RECOMMENDATIONS
