Hello chaps. I have a vertical radiator installed in the hallway, the pipework for which is sleeved and chased into the wall. Flow enters the bottom right of the rad, return is at the top left. Right angle lockshield and TRV are installed with the compression fitting pointing straight back towards the wall. As the rad hangs very close to the wall, the backnuts on the compression fittings are butted right up against the wall, and there are no exposed pipework tails.
As the plumbing runs down vertically from upstairs, it would be handy to have some method of draining down at this low point in the future. For the reasons listed above, there is no possibility of fitting a standard valve set with inbuilt drain cock. However, due to the valves being fitted at vertically opposite ends, I do have a spare 1/2" BSP thread at the bottom of the radiator that is currently plugged. Does such a thing as a chrome 1/2" drain cock exist that could be fitted in there? I know that I can remove the plug and drain down that way, but I've done it once already and it was a complete PITA.
Cheers!
Cheers!
