1 Bar tap on Gravity fed water system
12 Mar 2013
London
Hi guys,
I have a Bristan Kitchen Tap which says - minimum 1 bar. I have a gravity fed water system, so the pressure is about 0.5bar
Will the Bristan tap work ok? I do not need anything special, as long as water flows slowly.
Hi guys,
You will/should get about 70% of the designed 1 bar flowrate.
Stick it in and and try it. See if it is good enough. You will get some flow, how much is anyone's guess TBH.
