1 Cold radiator 1 pipe hot other end cold
8 Dec 2009
Manchester
I have 1 cold radiator 1of the pipes is hot the other end is cold Ive checked the TRV its ok rad is new, any offers please.
Bled out air till running water came out and let run for about a quarter bucket then other pipe came warm for a while but norad heat gone cold again now. many thanks lets get it sorted
Other end fully open TRV fully open, TRV end pipe cold other end pipe hot but no heat in rad
I may try that at the weekend cant go without any heat at the mo its freezing here, Cheers
Do i need to turn off all rads the problem one is in the kitchen? once turned off and turned back on is that it" balancing"
Many thanks,
Al.
Many thanks,
Al.
Just turn 2 or 3 off to start (best with all though) as this means the only place for the water to go is the cold rad, i may be very wrong but i doubt if its a new TRV its not Bi Directional.
I will get the nescessary equipment, give it a go & let you know.
Thanks for the quick response.
Al.
