I have a single radiator downstairs which is not getting warm at all and I running out of options before calling a plumber. All other radiators are perfectly hot.
I have done the following which has not fixed the problem.
1. Bled the radiator. Cold water flowed out
2. Removed the TVR Value head on the outlet side and made sure the pin was free to move. (It was, but am I right in that it should only move a few millimetres rather than a large amount?)
3. Switched off ALL radiator except problem radiator. Now this caused my boiler to stop working. It didnt seem to want to fire and pump any water round. Turned back on the radiators and it fired up perfectly again.
4. Checked that there wasnt a blockage inside the inlet side of the radiator by removing the inlet pipe and checking that water flowed out of the radiator.
5. Checked the inlet pipe to the problem radiator. The water seemed to flow out of it but only a slow trickle. Is this normal? This water eventually got warm but it didnt seem to fix the problem.
Is there any other things to try before phoning a plumber?
Thanks in advance
Neil
Thanks in advance
Neil
