The kitchen radiator was turned off for painting. Afterwards the radiator was bled & became hot immediately.
Since then it has been stone cold, although the 2 pipes leading into the rad (both pipes at the same end of rad) are hot.
Can anyone help. I heard something about turning all the rads off and "boiling" the air lock (if it's that) out of the top of the system. If this is the case do I turn all the rads off apart from the highest one or not?
Any advice would be gratefully received.
