Hi Everyone, This is my first post and I think it may be a rather atypical situation, so I will provide some background information, but will try and keep it brief.
Seven years ago we bought half of a house. It is over 100 years, 3.5m ceilings, all one level, solid wall brick construction, external wall insulation. Total of about 190sqm. The house had long ago been divided (or perhaps originally designed as two joined by a common entrance and corridor). We did a complete renovation of our side of the house (90sqm) including all plumbing and heating. A 20KW gas combination boiler provides hot water to 1 bathroom and a small kitchen and heat to the radiators. It works great, and we are very happy with the performance. No complaints.
Three children later and feeling a bit squeezed we have just purchased the remaining half (100sqm) of the house from the elderly couple next door. The new side of the house will require some serious renovation work, including plumbing and the heating system, which must be replaced. There is a VERY old inefficient gas boiler that has to go.
We plan to join the two halves as one seamless home. The old half will be the sleeping area, and will require only a few minor modifications. The new half a large kitchen, open plan dining/living, 2nd bathroom, large entrance corridor, and an additional bedroom (small).
Clearly our existing 20KW boiler won’t handle the load of the 2 bathrooms and extra 100sqm. The simplest option is to replace it with something bigger to run the entire house. Or does it make good sense to install a 2nd boiler for the new half, and run it as a 2nd independent zone?
To complicate things further – the new half of the house has suspended floors, and I may (it isn’t clear yet) end up lifting most of them and replacing – tiles for the bath/kitch/corridor and hardwood for the living area. Would seem like a great opportunity to install wet UFH. In this situation would it make even more sense to install a second, high efficiency condensing boiler to run the UFH, and leave the original boiler for radiators in the bedrooms and hot water to the taps? I should add that the open plan area will also have a fireplace.
Thank you in advance for sharing your thoughts and experience.
