One of my cast iron bathroom rad's valves is knackered. While I may be able to fix it if I took it off this is a drain the system job so I want to have a good replacement if necessary. BUT, measuring similar valves since taking those rads off to be sandblasted it looks like the rad-side fitting is 1 inch and I can't find anything with a 1 inch fitting.
Have I measured it wrong? Will 22mm or 3/4 inch work? The pipework is 15mm. I may just drain the system to take it off and have a service valve handy... Even so, anyone heard of a 1 inch valve? The only company I can find on google is radiator plus in Ireland
Cheers!
Cheers!
