Hi all- many thanks in anticipation for any replies!
I've recently had a problem with one of my downstairs radiators- it was only getting warm at the top, so, following the advice on these pages, I removed it from the wall and flushed it with cold water from a hosepipe in the garden, assuming it was clogged up with sludge. There was definately some sludge coming out, but eventually the water turned clean, and i could tell the rad was clear.
I then re-hung the rad, checking that the TRV worked, and the return valve (lockshield valve?) was open.
After the boiler (4 year old combi) (rads + pipes 11 years old) was re-pressurised and switched back on, I bled the rad, but it didnt get hot at all, though all of the others on the system did.
I then turned off the other 5 rads with TRV's, (the bathroom and kitchen dont have TRV's) to see if that worked (it didn't).
My next step after tonights research is to turn off the other 2 rads using the lockshield valves, and try again.
Is there anything else I can do to get this rad working again? I have a gas safe engineer coming in a months time to service the boiler- maybe I should leave it to him?
Most of the pipework in the house is 'pushfit' (?) Would that have any effect on the problem?
Many thanks again for your help!
Btw- any recommendations on cleaning up after getting covered in black rad water?!
