Just replaced standard 1 way 2 gang light switch with equivalent 250w dimmer. This is lineked to 2 ceiling lights, each with 5 60w candle bulbs.
I copied the wires over exactly but I did notice that the red wire linking the two transformers was thinner than standard.
However the lights worked fine for the first day, but then one set of lights (furthest away) started to flicker, usually when on near or full power, they then automatically dimmed, you can power them back up again but they continue to flicker until you reduce the power.
