Hi All,
I am hoping some of you experts can help please???
I had a single switch which controlled two separate lights (2 individual flex's coming from separate parts of the celling both with an energy saving light bulb on each)
We decided it was time to become a bit posher and change these for matching light units with three bulbs on each unit. This would cause a problem that the light would be too intense with an either ON or OFF selection, so I decided to get a dimmer switch. (so a single dimmer switch controlling both light units)
I assumed this would be a straight forward process by changing everything like for like (wiring wise) and I'm pretty confident I done this.
Once it was wired up, I switched the fuse box back on and 1 of the light units was constantly on and had no effect or worked in any relation to the light switch. The other light unit worked correctly to the switch (Push in and out, it came on and off and dimmed correctly.) But the other one stayed on constantly!!!!
(I am using 3 off 24w non energy saving light bulbs on each unit)
I thought "I know what I've done! I have got the Live and Neutral the wrong way around" I check and it seemed correct but I changed it around to make sure. This had no effect whatsoever, it still stayed on constantly.
Is there any sparky out there that knows exactly what balls up I have made or is this a dimmer switch thing?
Thanks for your help in advance!!
Still No Dough Daz!!
