1 x fan, 2 x rooms, 2 x lights, switching
21 Dec 2008
Lancashire
I have added a second bathroom and created an effective extraction system using one mixed flow fan, with timer over-run (hence switched-live connection), ducted to both 'rooms.
I should like to be able to switch the fan on from either room and to also have these switches activating a LV in the respective rooms. This is partly to encourage switching on/off of the fan.
My electrician says that it can only be done with relays and implied it was complicated. I have given it some thought and come up with the circuit shown (please excuse child-like rendition on MS Paint), using 2 additional two-pole switches.
View media item 7017
Can anybody please tell me whether this is a reasonable/workable/acceptable solution before I suggest it to the electrician.
no as either switch will turn both lights on
listen to your spark he is correct
not too complicated though
matt
matt
That won't happen as the switches are double pole so the fitting which hasn't been switched on will lack a neutral.
However, it's very poor circuit design and not something I would install.
Hint - listen to your electrician.
hey gary your right I didnt notice the double pole switches
that will teach me for jumping in too quick
but regs wouldn't allow it anyway
matt
Removing the neutral for the purpose of switching is not permitted by the regs.
Mainly because it is VERY dangerous.
Stick to your day job and listen to your electrician.
That would do it TicklyT, might need to re-jiggle it a little bit to install a fuse if the fan manufacturer says it needs it.
TicklyT's method is correct, I've installed and encountered such designs, it's not all that uncommon, especially when you have a bathroom/seperate loo. In fact I've done one on a ongoing job, bathroom+ utility, both fully internal with difficult ducting. (and so will have the most powerfull 4" inline fan I can find...)
A big "Thank you" to all who have replied and especially TicklyT for taking the time to draw the circuit. It has all been extremely helpful.
Could I just ask your opinion as to the relative merits of this solution compared with the one involving relays. Obviously Hairyben has opted for it some cases, is that for cost or simplicity reasons, or maybe something else?
BTW Hairyben, the fan I am using is a Vent-Axia ACM150T and I am very impressed with the performance, it manages to eliminate condensation even when split between two ducts, and one is over a power shower. It was too much for just one shower: like standing in a strong wind when naked and wet:-causing many complaints from family. Mind you, I am using 150mm ducting as well. They do make a 100mm model too.
Thanks once again to everybody
