Does anyone see any problems with branching off a 22mm pipe to a 7700 btu radiator in 10mm?
The whole house its branched off 22mm to each rad in 10mm so pipes can be hidden in walls.
Its running from a 30kw condensing boiler with 8 rads in the house.
Does this seem ok to do or would you use 15mm for this one rad due to the size?
Thanks for your help.
