10' x 8' Breeze Block Shed/Office
7 Aug 2014
Essex
I want to build a breeze block shed/office which would sit on an area approx 10x8.
Would standard hardcore then concrete base with reinforcing mesh be ok to build on?
I'd just like to know which options I have, it doesnt have to be breeze block but I just thought it would be easier and cheaper as its not too heavy. But I'm open to the idea of timber frame if need be.
build it off a normal strip footing. Its a bit more work but trying to waterproof the wall/slab junction on a raft footing is incredible difficult to do right.
Sorry to jump in on this thread but what's 'strip footing'?
Also does a block shed need planning permission?
Strip footings are basically trenches filled with concrete dug to the correct depth and width on which you can build the blockwork. This is as opposed to building an entire slab of concrete then building on that.
The experts here (perhaps in BUILDING) will advise you as to the correct depth/width/mix etc.
As for permissions, see below.
B
http://www.planningportal.gov.uk/permission/commonprojects/outbuildings
Depending on what the ground is like, what kind of load the workshop will have and the type and number of trees around you might be better of with a raft than strip.
