Im building a boiler house which will only be 1 metre deep but is 5 metre wide and needs a vertical roller door to allow access to the boiler and and the remaining space. Walls with be single block 4 inch thick.
I have purchased a 5 metre 10cm standard steel lintel to fit across the opening, which will carry 40cm high of blocks, I now just realised the lintel is slightly wider than the 4 inch blocks which are measuring at only 9-9.5cm wide. The lintel will have to be flush with the internal block wall to allow for the roller door guides so will stick out 0.5-1cm on the external face. Is this an issue or will it be fine once outside walls are rendered and so end up flush?
Also would anyone have any advice on how much support to leave on the single skin wall? I've allowed for up to 40cm support either side.
Thanks guys
*Edited for measurement types -really sorry thanks for replying,
Lintel is 10cm deep so issue is it is sitting out over 9-9.5cm blocks. It will be carrying just enough blocks to hold the 35cm brackets of roller door.
Thanks guys
