- Joined
- 17 Aug 2005
- Messages
- 13
- Reaction score
- 0
- Country
Ive purchased a 10a under counter "wedge style" switch from tlc with the intention of using it to switch 4 x20w lv halogen under counter lights.
I was proposing to take a spur from the ring main to a fsu (with 5 amp fuse) and then from the fsu onto the lv lighting with the aim of the lights being switched by the 10a undercounter switch. Two questions:
1. Does the switch operate after the transformer on the 12v circuit or before it on the 230v?
2. The switch itself only has two terminals labelled in and out so how should the switch be connected? (I was originally assuming there would be a live and a neutral in the switch housing - aka like a "normal" light switch that I could then run to a ceiling rose type device to which the transformer is connected?)
With these questions in mind can anybody enlighten me with the correct wiring diagram?
Thanks in advance for any words of wisdom.
Sorry - by under counter I obviously? meant under wall unit! Doh!
__________________________________
moderator
please note 10a
moderator
please note 10a
