Soon to change a WC and see that a lot of them have a 10m feed.
Is it Ok to use with a non mains feed? I live in a flat and cistern is fed from a tank nearby.
Any help thanks.
I'm looking for a compact size, the one's that I've seen in B& Q and Wickes are 10mm.
The pipe run is in 15m so if I reduced just before entry into the cistern to 10m would that help the flow at all?
absolutely, it would make a noticeable difference to stay with 15mm as far as you can, the valve itself is a restriction and the last little bit of 10mm will make little difference. as long as it is kept minimal.
thanks for your replies.
It's in a flat so not much head about 1 mtr from bottom of cistern to bottom of cold water tank.
The flow out of the taps from the nearby sink is quite good but then thats in 15m throughout.
as others have said,, it wont be great, but you can only pee woth the c**k you have got, however the best way to do it isd to get a 15mm FI adaptor, with a brass bush (i think 10mm is 3/8", so you want a 1/2"MI x 3/8" FI bush) screwed into it fitted right onto the ballcock, rather than any 10mm pipe at all,
