- Joined
- 29 Jun 2021
- Messages
- 125
- Reaction score
- 5
- Country
As part of an ensuite refurb, I need to move the pipework to a towel rail - currently 10 mm plastic. This will mean channelling the wall again and obviously I don’t want to go to deep on this.
Don’t like the idea of putting a plastic fitting in the channelled slot and so my initial thoughts were to go with microbore and put in a 90° elbow, But then I saw a video of microbore bent through 90° using a bender and it was tighter than I was expecting; or at least that’s how it seemed in the video!
So my question is, is it feasible to do away with the soldered joint and just rely on the pipe bent in a bender? Clearly it is not going to be as tight as a soldered joint, but will I get away with it or is there some reason I should avoid this approach? I don’t currently have the pipe to test this on, hence the question.
TIA
TIA
