I am replacing the aged existing radiators in my bungalow and want to chase the pipes in the wall. I was planning on using 10mm (flow/return) JG speedfit inside 22mm oval conduit, with alu tape for pipe detection. Pretty straight forward thus far, however, the mrs wants the rads under the windows.
The problem is this; I can chase a vertical down one side of the window (which are 2M wide) but what do I do then? Do I cut a horizontal chase (create a L shape chase) to the centre of the window? Does this (horizontal chase) weaken the wall considerably?
Many thanks
Many thanks
