I had to cut into some 10mm plastic CH pipe the other day to clear a blockage - took an offcut of the pipe to local DIY store and asked for something to join it back together to which they recommended a push fit coupling. I used this and all is fine - at the moment!
I have since realised that maybe they should have inserts in the ends of the pipes before going in the push fit coupling - is that right? I am storing up a potential leak one day by not having them? The 10mm doesn't feel very squashable but then with hot CH water in maybe it is more pliable. If I need them, are they just generic things or is it specific to the make of pipe?
