10mm plastic to radiator
20 Mar 2009
Sheffield
Sorry this is probably a daft question but i'm going to ask it anyway. We had our old central heating system (back boiler with immersion tank) pulled out and a new combi boiler fitted a few weeks back. While the engineer was fitting the new system I asked if he could run us a new loop for the garage. We're due to start work on converting the garage into a habitable room next week so it made sense to have the pipework in place for the garage. I've just gone to look at the new loop/pipework and can see he's left us a long coil of 10mm plastic piping in the corning of the garage.
Couple of questions if I may:
- We'll be fitting the new rad with trv's. What would be the quickest & easiest way to plumb it in? Can you put 10mm plastic straight into rad valves or do you need to go to coper first? At the moment i'm thinking a pair of 10mm plastic to 15mm coper elbows under the floorboards. Then using a few very short lengths of 15mm coper into the trvs? Is there a easier way to do this?
- The new loop appears to be live as he's not added valves. I guess i'll have to drain the whole system, cut the loop/pipe and run them to the new radiator. Once I've cut the loop, does one act as a feed (ie: have the trv) and the other act as a outlet (normal lock shield valve)? How do you tell which is which?
*copper
You'll be fine with 10mm plastic going straight into the valves. Pushfit elbows are available to convert 15mm valves to 10mm pipe.
Does the new loop get hot when the heating is on? If it does, it's live. If it doesn't, it's probably not connected. You'll need to identify from the main pipe runs which is flow and which is return.
ok cheers, will stick with 10mm plastic and buy some inserts so I can connect them into the trv's
