I've got a Duravit cistern which comes with a compression joint for 10mm pipe on its base. I'm wanting to connect it to the 1/2" female thread of a flexible hose (braided stainless steel type).
How should I do it?
I'm thinking - short section of 10mm pipe to 10mm/15mm reducer (compression fitting) with the flexible hose screwed directly to the reducer.
Is there any way around using some 10mm pipe? Like can you get a reducer fitting that will screw directly onto the male thread on the cistern (size ?) and provide a 1/2" male thread for the flexible pipe?
How should I do it?
