10mm to 15mm reducer elbow coupling
10 May 2011
Warwickshire
Hello
I am in the process of trying to connect a 10mm pipe to a 15mm pipe that are at 90 degrees to each other.. Hence I am looking for a 10 to 15 mm 90 degree elbow.
There isn't the room in the area to add say a 10 - 15 then just use a 15mm street elbow. I've been looking around and although I can find a compression version, I would prefer a solder one as there is limited room and would be interesting to try and get any spanners in there to tighten a compression elbow.
Thanks all
Only fitting I know would be a reduced end tee and cap the spare end, or stick a draincock init
10mm to 15mm end feed that fits into a 15mm elbow is that not tight enough for ya only about 10mm longer than a 15mm elbow
