110mm strap on boss on 100mm cast iron pipe
23 Mar 2015
Nottingham
I have a cast iron internal soil pipe 100mm and I am wanting to add a join with a strap on boss but I can't find much for a 100mm pipe I have seen a cast iron strap on boss at 100mm, but the plastic are 110 any advice on what is best to use and if u recommend using a strap on boss thank you
Thank you for the link I have seen this one I just not sure which is best to use as not seen much about the cast iron ones and they are a lot more expensive just don't want to end up buying one an find out they aren't any good cheers
I have used the normal ones on cast, I use silicone instead of solvent adhesive, just be prepared for a long drilling session, also worth using cutting oil on the drill.
Thank u for the links would those with no straps stay stuck in place or eventualy come off and them white one with movable straps I read that they can snap quite easy has any one used these and we have a 110 strap on boss but it is quite loose around the pipe, when u have used them with silicone do they last with out leaking
I have a new dilemma it isnt actually 100mm as I thought it is 90mm any ideas for this one cheers
