115x20mm skirting?
30 Nov 2013
Essex
We've just had some skirting replaced and the electrician has damaged it by hammering it to the wall along its length. It's now ruined.
I'm now trying to find a suitable replacement and the only bits I can find are slightly off in either dimension.
It measures 115x20mm.
Anyone any bright ideas please?
I don't have the facility to accurately trim off some height of a slightly taller piece...
Thanks!
I was going to say buy a taller piece then rip it to the required width...... Even a handsaw would do the job - you can always hide the sawn edge at the bottom and disguise the joint with caulk. In any case, how will you cut it in if you can't resize it?
I have a mitre saw, so I can cut it in, but I obviously can't do this along the long edge.
I need the cut to be clean as there's no carpet, so a hand saw is not an option.
Oddly enough with a £10 hand saw and a bit of practice even our apprentice manages to cut a clean edge which requires minimal cleaning up with a sanding board (sandpaper stuck onto an offcut of MDF) or a block plane. But then he's lousy at making tea! You don't need power tools for everything :eek:
Can you upload a pic of the damage. If there's hammer holes on the flat part, then just use 2 part car body filler, and sand it before it goes rock hard. If it's on the profiled part, then the same principle applies, but it requires a bit more care to sand and trim it
