This article seems to disagree with you https://www.energyvanguard.com/blog/what-happens-air-flow-ducts-when-size-changes It seems that the flow is not reduced but the air pressure exiting the duct increases.You’ll reduce the possible air through the duct by about 40%. Will that be sufficient air throughput to adequately clear the room? There are lots of room/fan calculators on the Internet so you can check.
Why not do it properly and use 125mm duct, etc.
The air inlet for an in-line fan can go anywhere you like. I assume it doesn’t have any electrical component (like a light) in it?
PS pedantic point: a vent is where the air extracts from, not where it comes in!
Aside from the performance issues, it will make more noise, I guarantee you. That would be enough for me to not do it.
What, using 100mm ducting on a 125mm fan as opposed to 125mm ducting will be noisier,
Ok, thanks. I'll see what it's like once fitted and swap to 125mm later if it's an issue. Cheers.Yes.
