I was hoping that someone could give me some advice please.
I have a combi-boiler and mains fed cold water (with reasonable pressure) but no tanks.
In the past I have always used electric 10.5kW showers which were fine but fairly ugly.
I have just had my shower room redone and was told that I would have sufficient water pressure to run a rainfall shower via a mixer system but unfortunately that is not the case and it is far too feeble.
Having had the rainfall shower head installed and the tiling replaced etc I was hoping that I could find a way to use them.
Is it possible to run a 12kW water heater in series after the combi-boiler to produce higher temp water for the same flow rate and then mix this with mains fed cold water in the mixer to allow a greater water flow rate overall at a reasonable showering temperature? I have 10mm cable in situ - would this need to be increased?
If not is there an electric shower that would produce a sufficiently high flow rate for a rainfall head?
I would be very grateful for any suggestions!! Thanks
