12mm MDF wardrobe
29 Mar 2011
London
Hello all
Iv made a bit of a booo booo iv made a waderobe/cub out of 12mm MDF and tryed to use EASY MOUNT HINGES to try and match the conceled hinges on the 18mm cubs in the rest of the house, they are utter crap and cant find anything else like them they dont adjust as good.
my question is can i add a strip to the inside of the door or frame to use conceled hinges or will the doors not close flush? im open to ideas please help and thanks
Should have used 18mm, but you should be able to glue and pin internal timber to fix hinges.Though I would replace with 18mm mdf.
i know lesson learnd never again and il never use those hinges again
will it not affect the swing of the door thats what im worried about
would 18mm doors work with 12mm frame?
If you use kitchen style hinges then the thickness of the sides does not affect the closing though they would need extra strip of timber or mdf to build them out sufficient to take screws.
If you make the door up to 18mm thick where the hinges go, then cut them in, they will work. Any thicker and the hinge plates will need to be set back further into the carcass which will cause the door to bind. Any thinner and you risk coming through the face of the door when drilling out for the hinges.
im thinking now il change the doors for 18mm to stop bowing aswell
