- Joined
- 19 Jun 2010
- Messages
- 36
- Reaction score
- 0
- Country
Hi I know you are probably sick of downlighting questions but I can't seem to find a definitive answer to my question. I an fitting 4 50w downlights in my bathroom (all ip rated showerlights) I have one transformer which is suitable for up to 250 w, it has four output blocks so each of the four lights has it's own cable running from the transformer. So to sum up ceiling Rose fed into 1 transformer with 4 outputs 1 twin cable per output. The longest output is 1.2 metres. I tried wiring it with 2.5mm cable I had in the garage but it's too thick for the output terminals on the transformer (the cable gets pinched when I try and put the cover back on. What size of cable would you all recommend for this ?? Is 1/1.5 sufficient ??
All advice gratefully received. Thanks
