Hi
I moved into my house 3 years ago.
The kitchen has those 12v halogen spots - the ones flush with ceiling & spring clip to release the bulb.
One of them is very temperamental - it works for a bit, then goes dead.
If I wiggle it in the connector it works again e.g. push it all the way in, or pull it half way.
Then it will go off again after a short while.
The bulb is OK as it works in other sockets. The terminals on the bulb are rather dark (?carbonised) - not sure if this is relevant.
This happened to the neighboring bulb a year or two ago - I ended up replacing the box the connecting wires are attached to (?transformer). This worked for a bit, but then it played up again. But recently that bulb has been behaving.
It's quite frustrating - what could be causing this ?
thanks
thanks
