That heater requires a 20A switch for the off peak supply and an FCU for the daytime/peak supply.
The same applies to pretty much any other modern storage heater.
Which supply? The XLE070 requires two supplies
- Off peak - rated at 1.5kW. normally this is fused in your off peak fuseboard/consumer unit. (I guess you have one?)
Usually a 16A MCB etc is used so a second fuse at the heater is not necessary.
- A 24 hour electric supply. This is only used for the boost fan and to power the timer display. The fan is only rated at 11 watts, so very small current needed.
