Need to put a new opening in block wall for door.
Blocks are 150mm wide the lintel will only be supporting 4 courses of blocks with nothing on top of those.
Space is tight above opening for door so could I use lintel on side so 65mm is the height?
It will be a concrete lintel, as below
https://www.travisperkins.co.uk/Sup...te-Lintel-65mm-x-140mm-x-1200mm-P150/p/700520
