I am planning what work needs to be done when the electrician comes in to the inspection and upgrades. We have an old 8 way Wylex consumer unit with wired fuses, as the electrics would need to ideally last another 20-30 years I think this needs to be replaced.
The earth bonding is very very poor and this needs upgrading.
The main issue is a severe lack of sockets and there is only one ring main. Ideally this may need to be split and around 10 sockets need to be installed in different places.
Also all the main cables are buried behind door frames and plaster and this resulted in the main income fuse being blown when it one off these wires was accidently drilled through. The electricity board did come out and replace the fuse free of charge, which was good of them.
When this happened the main fuse blew but none of the fuses on the consumer blew and a relative that used to be a spark many years ago suggested there was something wrong, as the fuse on the circuit which affected should have blown rather than the main one.
The lighting circuit seems fine and is earthed. Just two issues here the wires again are just under the plaster and the bathroom light low voltage down lights are not of the correct IP rating so will need to be changed.
So given this information and the fact a lot of work needs to be done on the ring main to avoid the spaghetti junction of extension leads we have no, would it be best long term just to rewire the entire lot but keep the lighting circuit or would the fact we will have RCDs mean the wiring under the plaster is no longer a problem?
Sorry for the poor spelling/missed out letters I am typing on my laptop running Linux and I haven't got the correct drivers for the trackpad, which results in the cursor jumping all over the place deleting the odd letter or word.
