I am looking at replacing my boiler with a heat bank on a vented system or an unvented system. I had British Gas in yesterday and they advised me that my mains water pressure was around 15 litres per minute and that would really defeat the benefit of using one of these systems and unless I can up this I might be better sticking with a conventional system.
My house was built in 1874 so there is a possibility that the original mains pipes are in place and I can up the pressure by getting a new main installed. I have phoned my water authority to find out if they knew what pipework was there and they were not very helpful saying that it is not there problem.
Is it worth getting a plumber in to look at upgrading the mains (I assume that there is no guarantee that it will increase as the bore of the mains pipe might not be the limiting factor)? Would it b sensible to find out if my neighbours are getting better pressure thereby indicating that there may be improvement to be had?
Is 15 litres per minute enough given that we have 3 bathrooms, kitchen etc. that may need to draw water at the same time for a stored mains pressure system?
Thanks.
Thanks.
