You cannot make meaningful scientific comments on this.
The effect on the flow rate of different resistances depends on the supply pressure.
That typically varies between a static pressure of 1.0 bar and 10 bar in domestic properties!
Tony
Tony, I think my comments were quite in order for my given scenario (my own dwelling). Please correct the assumptions in my post if you think not.
I was simply indicating that in
my house the supply pressure is sufficient to deliver more than enough hot water flow to my kitchen sink through about 8 mtrs of 10mm copper pipe, where in comparison this flow-rate would be less than ideal for my bath, hence I'm using 15mm pipe for that.
My post however, was mainly trying to indicate the relative static volume of pipes of differing diameter, and hence the
potentially wasted energy involved in their use. This goes for water wastage too.
Obviously you clearly understand these concepts, but it may not occur to the layman.
For example, if I'd just run an amount of hot water off through a 22mm pipe, which was well lagged, then the water content of that pipe may indicate completely wasted energy if I didn't then draw any more water for say 30 minutes, as that water-mass would have lost too much energy to be at a useful temperature. If however I'd have drawn hot water within only say 5 minutes, then the water in the pipe may still have been at a useful temperature to me. Conversely, a thinner pipe, containing a relatively lesser capacity of water will not hold as much energy, so may be too cold after just those initial 5 minutes, but then much less energy has been wasted if my next demand is not for 30 minutes.
I'm not a plumber, or a heating engineer, but I am a properly qualified 'Engineer' (meaning a degree qualification in a proper engineering discipline, plus 25 years industry experience)
I'm really interested to know about your experiences out there... how often do you see literally 10 bar static mains pressure in domestic properties... isn't this rather exceptional? I remember a whole housing estate in the news because their pressurized hot water cylinders were all developing leaks because the mains was coming in at 10 to 12 atmospheres.
regards
