Is it OK to run 15mm pipe behind dot and dab plasterboard. I am having new radiators fitted in an extension and the easiest and neatest way to route the pipe is down the wall and then dot and dab with plasterboad. It will be a straight drop to the radiator so should be easily identifiable as to where the pipe run is.
